1747337972
Skip to main content
Unit Challenge
Now that you've explored coding with the AI Vision Sensor on your VEX AIM Coding Robot, it's time to put your skills to the test! In this unit you learned about how the AI Vision Sensor can use visual data to interact with objects in its environment. You turned to and got barrels, and moved them to AprilTags using sensor data. Now it's time to apply everything you've learned to a sports ball challenge! You will collaborate with your group to strategize how to pick up and kick both sports balls through the goal. Then you will work together to code the robot to complete the challenge, iterating on your project to score both goals as quickly as possible.
Review the challenge by watching the video below, and think about how you will complete the challenge with your group.
Complete the Challenge
Share Your Strategy
Reflect and Share
Select Return to Units > to go back to all units.
