Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
ACTS | ASKS |
Getting the Students Ready to Build
Before we can start coding our Code Base robot rovers, we need to build the Code Base!
Facilitate the Build
- InstructInstruct students to join their group, and have them complete the Robotics Roles & Routines sheet. Use the Suggested Role Responsibilities slide in the Lab 1 Image Slideshow as a guide for students to complete this sheet.
DistributeDistribute
build instructions to each team. Journalists should gather the materials on the checklist.
Code Base - LED Bumper Top -
FacilitateFacilitate
the building process.
- Builders and Journalists should begin building based on their roles and responsibilities, like those shown in the Lab 1 Image Slideshow.
- Circulate around the room to help students with building or reading instructions where needed. Ask questions about how the build is being constructed to keep all students engaged in the buildings process, and remind students to follow their Role Responsibilities if they need help taking turns.
- OfferOffer suggestions and note positive team building and problem solving strategies as groups build together.
Teacher Troubleshooting
- If the wires seem to be getting in the way for students, use a rubber band to pull them together, and you can tuck the bundle into the build if needed, to keep the wires from impeding the movement of the Code Base during the Lab.
- Throughout this Unit, students will be adding “sample” items to the top of their robots. To ensure that these additions do not interfere with the movement of the Code Base, make sure the additions are lightweight and do not touch the ground when the robot is placed on a surface.
Facilitation Strategies
- Think about how your students will access VEXcode GO. Ensure that the computers or tablets that students will use have access to VEXcode GO. For more information about setting up VEXcode GO, see this VEX Library article.
- Gather the materials each group needs before class. For this Lab, each group of two students will need a GO Kit, Build instructions, a computer or tablet to access VEXcode GO, a small classroom item to act as a sample, and access to a GO Field for testing.
- Set up your Fields ahead of time, as shown in the image below, to serve as a testing area for the Code Base rovers. Mark the start and sample locations, as shown, using a dry erase marker, or classroom items. Have these spread out around the classroom to allow students ample space to test their projects. Both Labs in this Unit will use the same Field setup, so you can leave your fields together from Lab 1 to Lab 2.
- Try another project - If students successfully reach the sample location right away, encourage them to try navigating to a different sample location. Use a dry erase marker to mark a sample location that is closer or further from the base, and have students adjust the parameters of their project to reach this new sample location.
- Try a Turn - For groups who finish early, and need additional challenges, have them add a [Turn for] block to the end of their project in Play Part 1, and test it to see what the Code Base will do. Ask them to experiment, and think of ways that this block could be useful in collecting samples on the Field.
- Use the Get Ready...Get VEX...GO! PDF Book and Teacher’s Guide - If students are new to VEX GO, read the PDF book and use the prompts in the Teacher’s Guide to facilitate an introduction to building and using VEX GO before beginning the Lab activities. Students can join their groups and gather their VEX GO Kits, and follow along with the building activity within the book as you read.
- Use the Teacher’s Guide to facilitate student engagement. To focus on VEX GO connections in a more concrete or tangible way, use the Share, Show, or Find prompts on each page to give students an opportunity to get to know their kits in more depth.
- To focus on the habits of mind that support building and learning with VEX GO, like persistence, patience, and teamwork, use the Think prompts on each page to engage students in conversations about mindset and strategies to support successful group work and creative thinking.
- To learn more about using the PDF book and accompanying Teacher’s Guide as a teaching tool any time you are using VEX GO in your classroom, see this VEX Library article.
