Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
| ACTS | ASKS |
Getting the Students Ready to Build
Now that we know what the problem is, we can start to work on our solution! We will need a Code Base 2.0 robot and an extension arm to gather up all this trash.
Facilitate the Build
- InstructInstruct students to join their team, and have them complete the Robotics Roles & Routines sheet. Use the Suggested Role Responsibilities slide in the Lab Image Slideshow as a guide for students to complete this sheet.
DistributeDistribute
VEX GO Kit and a set of Code Base 2.0 build instructions to each team.
FacilitateFacilitate
building process.
- Builders and Journalists should begin building based on their roles and responsibilities, like those shown in the Image Slideshow.
- Circulate around the room to help students with building or reading instructions where needed. Ask questions about how the build is being constructed to keep all students engaged in the buildings process, and remind students to follow their Role Responsibilities if they need help taking turns.
- OfferOffer suggestions and note positive team building and problem solving strategies as teams build together.
Teacher Troubleshooting
- Offer suggestions on the purpose of the creation such as, “what will this gear achieve?”
- Divide each group’s workspace into two areas. One will be for the Builder and another for the Journalist.
- Remind groups to keep their building areas separate from others.
Facilitation Strategies
- Students may be tempted to work on two builds at once (the Code Base and the extension). Have each group raise their hands to show you their finished Code Base before allowing them to begin working on their designs for the extension.
- Note about extension: Make sure the extension does not touch the ground or impede the movement of the Code Base.
