Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
| ACTS | ASKS |
Getting the Students Ready to Build
Now it’s time to build the Code Super Car. Groups will pair up in order to combine their Motorized Super Car to create the Code Super Car.
Facilitate the Build
InstructInstruct
students that they are going to pair up with another group to join their Motorized Super Cars together to build a Code Super Car.
Code Super Car Build - Ensure each group has their own Motorized Super Car built before combining with another group.
- If students do not already have a pre-built Motorized Super Car, have each group build one first (before combining groups.) This will add approximately 10 minutes to the Lab.
- DistributeDistribute build instructions and Robotics Roles & Routines sheet to each group. Use the Suggested Role Responsibilities slide in the Lab Image Slideshow as a guide for students to complete this sheet.
FacilitateFacilitate
pairing up groups. Let students know that they will need very few additional pieces to complete the build. They should keep their Kits separate so as not mix pieces between Kits.
Have Group A use their Kit for the additional pieces needed. Have Group B share their Motorized Super Car only, and leave the rest of their Kit in a separate area. This will help with materials management.
- Have students use the Robotics Roles & Routines sheet to help students share the responsibilities. Encourage students to evenly distribute the central and support roles between groups.
- OfferOffer suggestions to evenly distribute the roles between groups.
Teacher Troubleshooting
- Make sure the Batteries are fully charged before the lab begins.
- If students are having trouble with the pins, offer the Pin Tool as support.
- Check in to ensure that students are properly inserting the cables to connect the Motors and Battery to the Brain. View the Using the VEX GO Motors VEX Library article for extra support if needed.
Facilitation Strategies
- Help students share responsibilities during Play activities - Students will be using VEXcode GO to connect their Brain to their device, configure VEXcode GO for ‘Super Car’ and naming, saving and starting a simple project to make their Code Super Car drive forward in Play Part 1. In Play Part 2, they will edit their project to explore the velocity control of the Code Super Car by running multiple timed trials in Play Part 2. Encourage groups to split up responsibilities between coding and materials management for activities. Students can take turns coding and starting the projects throughout the Lab, and the goal should be for each member of the group to have a turn to use VEXcode GO during the Lab.
