1730231542
Skip to main content
Teacher Portal
Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
ACTS ASKS
  1. On the board, draw a picture of a treasure map without lines with two spots for a treasure. See the example on Slide 4 in the Lab 1 Image Slideshow.
  2. As students start to talk to each other, begin to draw the next map (see an example in the Lab 1 Image Slideshow) that is in a grid style with numbers at the top and alphabet letters at the left side. Put a dot on 1A and 3C.
  3. Show the students the Battle Boats printout. Callout the coordinate plane on the page and show the x and y axis of the plane (also in the Lab 1 Image Slideshow).
  4. Point to the coordinates 3C. Scan your finger to show the x axis is the number 3 and the y axis is the letter c.
  1. Have you ever gone a treasure hunt? Did you use a map? How were you able to read the map? For many treasure hunters, maps help them locate areas that could have the treasure.
  2. Maps have lines that are on the x and y axis. Let’s draw one and now I’m going to put numbers at the top and letters at the side of the map. Now, looking at this second map, what changes do you see? Which map do you prefer and why? If I told you to go to 1A would you know where to go? What if I told you a buried treasure was in 3C would you be able to find it? This map is called a coordinate plane. This map has an x axis and a y axis.
  3. Today we are going to learn about coordinate planes. Coordinate planes are used throughout mathematics to help us understand geometry and algebra.
  4. Coordinates like “3C” determine where a point is located on a coordinate plane. Today we will be making our own coordinate plane to plot points on.
Getting the Students Ready to Build
Now, it’s time to build our very own coordinate plane, called Battle Boats! Now, let’s get building so we can start playing and plotting points.
Facilitate the Build
  1. InstructInstruct students to join their group, and have them complete the Robotics Roles & Routines sheet.
  2. DistributeDistribute build instructions to each group.
    VEX GO Battle Boats build, showing three boats attached out of GO pieces on the left and a pin and standoff on the right indicated guesses during game play.
    Battle Boats build
  3. FacilitateFacilitate building process. Have Builders and Journalists follow their responsibilities outlined in the Lab 1 image Slideshow.
  4. OfferOffer suggestions and note positive group building and problem solving strategies as groups build together.
Teacher Troubleshooting
Facilitation Strategies
  • Encourage Thoughtful Building in the Whole Group - As students are building, ask questions about the process to help them think about why pieces are going together in this particular way. For instance, questions about why the connectors are used instead of beams for the side walls, or what helps the build stop being movable, enable students in all roles to be engaged in the building process.
  • Strategy Shine Time - If one group gets done with the build, encourage those students to walk around and offer tips and strategies to other students. Allowing for these students to shine also gives more hands to help for groups that are slower at building.
  • Use the Get Ready...Get VEX...GO! PDF Book and Teacher’s Guide - If students are new to VEX GO, read the PDF book and use the prompts in the Teacher’s Guide (Google / .pptx / .pdf) to facilitate an introduction to building and using VEX GO before beginning the Lab activities. Students can join their groups and gather their VEX GO Kits, and follow along with the building activity within the book as you read.
