Skip to main content
Teacher Portal
Implementing VEX GO STEM Labs
STEM Labs are designed to be the online teacher’s manual for VEX GO. Like a printed teacher’s manual, the teacher-facing content of the STEM Labs provides all of the resources, materials, and information needed to be able to plan, teach, and assess with VEX GO. The Lab Image Slideshows are the student-facing companion to this material. For more detailed information about how to implement a STEM Lab in your classroom, see the Implementing VEX GO STEM Labs article.
Goals and Standards
Goals
Students will apply
  • How to collect and record data using the Eye Sensor.
  • How to make a visual representation of collected data.
  • How to interpret Eye Sensor data to support or disprove a claim.
Students will make meaning of
  • Analyzing sensor data to determine meaning, like the hue value of a detected object.
  • Identifying that data is a tool that can be used to test a hypothesis.
  • Comparing collected data to established criteria to determine whether a claim is supported or refuted.
Students will be skilled at
  • Opening and running a VEXcode GO project.
  • Viewing printed sensor data from a project in the VEXcode GO Print Console.
  • Collecting data about the condition of the bottom of a bridge with the Eye Sensor.
  • Using the hue values reported by the Eye Sensor to determine the location of cracks on the bottom of a bridge.
  • Recording and displaying data about the location of cracks on the bottom of a bridge in a Bridge Inspection Report.
Students will know
  • That data can be collected and used to support or refute a claim.
  • That data can be compared to given criteria to make a determination.
  • That data from a project can be printed to the Print Console in VEXcode GO.
Objective(s)
Objective
  1. Students will use the Code Base with the Eye Sensor to collect data about the bottom of a bridge, view the data in the Print Console, and identify whether or not the data indicates a crack on the bridge.
  2. Students will graph and record the data from the Print Console in order to determine if there is a crack on the bridge.
Activity
  1. Students will open and run a VEXcode GO project for the Code Base to drive underneath a bridge, and print data at incremental points about the hue value and distance travelled beneath the bridge using the Eye Sensor. They will discuss the data that was printed in the project, and determine the data suggests there is a crack in the bridge.
  2. Students will graph each data point from the Print Console in their Bridge Inspection Report. They will then identify the data points that correspond to a crack in the bridge, and record them in a data table.
Assessment
  1. During the Mid-Play Break, students will share what they noticed about the data that was printed in the Console. They should be able to explain that the hue values in the data indicate there is a crack present on the bridge.
  2. Students' graphed and recorded data should realistically represent what could actually be reported by the Eye Sensor. Students' Bridge Inspection Reports should also display accurate data collection.
Connections to Standards
