1722620198
Skip to main content
Speedy Delivery Preview
  • 12-18 years old
  • 45 minutes - 3 hours, 50 minutes
  • Intermediate
Preview image
Description
Students are asked to program a robot to navigate a warehouse and to prepare packages for delivery.
Key Concepts
  • Programing
  • Robot Behaviors
  • Iterative Design
Objectives
  • Apply building instructions to create a robot to complete a specific task.
  • Identify the applications of the [Spin for] and [Spin to position] blocks.
  • Identify the sequence needed to capture and transport an object to a specific location.
  • Explain the appropriate use case for the [Set motor timeout] block.
  • Use the Device Info on the VEX IQ Brain to understand the arm's and claw's ranges of motion.
  • Create a plan for sequencing the project's programming utilizing pseudocode.
Materials needed
  • 1 or more VEX IQ Super Kit
  • Roll of tape
  • Scissors
  • Meter stick or ruler
  • Engineering notebook
  • Aluminum cans or empty water bottles
  • A stopwatch or any device that can track a minute of time
  • 1.22 x 2.44 m (or 4 x 8 feet) open area
  • Optional: VEX IQ Challenge Field
  • VEXcode IQ
    • IQ Clawbot Template
Facilitation Notes
  • Ensure all required parts for the build are available prior to starting this STEM Lab.
  • Make sure that there is ample space in the classroom to measure and tape the layout of the "warehouse" that will be used in the activity. If you have a VEX IQ Challenge Field, the dimensions for the activity are the same as the field.
  • If multiple students will be downloading their saved projects to the same robot, have the students add their initials to the name of the saved project (For example, "Forward and Backward_MW). This way students can find and make adjustments to their projects and not others.
  • An engineering notebook can be as simple as lined paper within a folder or binder. The notebook shown is a more sophisticated example that is available through VEX Robotics.
  • Students can share their pseudocode with the teacher for feedback prior to creating the project for feedback.
  • Students can create and expand on the warehouse floor plan to explore different programming options.
  • The approximate pacing of each section of the Stem Lab is as follows: Seek- 65 minutes, Play- 45 minutes, Apply- 10 minutes, Rethink- 105 minutes, Know- 5 minutes.
Further Your Learning
English/Debate
  • Discuss the pros and cons of robots completing more industrial and professional tasks as technology develops.
  • Research and write about other areas where robotic precision is being developed or should be explored.
History
  • Write a paragraph or create a timeline sharing the highlights of industrial robotic development from 1954 until present day.
Educational Standards
Standards for Technological Literacy (STL)
  • 1.F
  • 6.D
Next Generation Science Standards (NGSS)
  • HS-ETS1-2
  • MS-ETS1-2
Computer Science Teachers Association (CSTA)
  • 3A-AP-13
  • 3A-AP-17
  • 3A-AP-22
  • 2-AP-10
  • 2-AP-13
  • 2-AP-19
Common Core State Standards (CCSS)
  • CCSS.ELA-LITERACY.RST.9-10.3
  • CCSS.ELA-LITERACY.RST.11-12.3
  • CCSS.ELA-LITERACY.RST.11-12.9
  • MP.5
  • MP.6
  • CCSS.ELA-LITERACY.RST.6-8.3
  • CCSS.ELA-LITERACY.RST.6-8.7
Texas Essential Knowledge and Skills (TEKS)
  • 126.40.c.5.A
  • 126.40.c.5.B
  • 126.40.c.3.A
  • 126.40.c.3.B
  • 126.40.c.3.F
  • 126.40.c.3.G
  • 111.39.c.1.C
