Skip to main content
Capstone Mission
Now that you have learned about what you will do in the Capstone Mission, you are ready to get started! You will follow a process similar to the one you used to complete the challenge mission in Unit 7. You'll begin by developing your flight plan, then practice your approach and refine your strategy based on what you learn. Finally, you'll take to the air, balancing speed and precision to score as many points as possible in this timed challenge.
A VEX AIR drone position in front of the ring tunnel on the competition layout. The ring tunnel has two red rings and two blue rings lined up in a row.
Capstone Mission
Phase 1: Develop a Flight Plan
Phase 2: Practice Your Plan
Phase 3: Refine your Flight Plan
Phase 4: Fly the Capstone Mission
Select Next > to move on to the Course Wrap-Up.
