Build Instructions
Build the Testbed
Follow along with the build instructions to build the Testbed.
Open and follow the steps to build the VEX IQ Testbed Google Doc / .pptx / .pdf
Build Instruction Tips
- All Steps: There is important information about which parts are needed for the step above the partition line. The number below the image of a part is the number of that part required in the step. There may be dimension information below the part to help identify which size to use.
- Step 1: Count all pieces before starting your build, including sensors and motors.
- Step 5 and 13: Flip the build over to add the blue connector pins as shown.
- Steps 21–23: These steps show you how to put together a single motor sensor group. You will build 4 of these in total.
