Skip to main content
STEMLabs IQ
Lab 8 - Changing Velocity
Improve Your Project
Setting Appropriate Velocities
You got your Autopilot to move at different velocities! Let’s explore how to set appropriate velocities to program your Autopilot.
  • The Builder in each group should get the hardware required.
  • The Recorder should get the group’s engineering notebook.
  • The Programmer should open VEXcode IQ.
Materials Required:
Quantity Materials Needed
1
1x1 Connector Pin
1
Charged Robot Battery
1
VEXcode IQ (latest version, Windows, macOS, Chromebook, iPad)
1
USB Cable (if using a computer)
1
Engineering Notebook
Before you begin the activity...
Before you begin the activity, do you have each of these items ready? The Builder should check each of the following:
  • Are all the motors and sensors plugged into the correct port?
  • Are the smart cables fully inserted into all of the motors and sensors?
  • Is the Brain turned on?
  • Is the battery charged?
